Revox A700 ASIC-Ersatz TCA561 Motorsteuerung
Guten Abend,
auf Grund diverser Nachfragen hier der innere Aufbau des kundenspezifischen Schaltkreis TCA561 für die Motorsteuerung der Revox A700.
Die Schaltung stammt aus der elektrischen Tanja, daher keine Garantie ob korrekt.
Sollte sich eventuell durch engagierte Kollegen in einen Huckepack-Print für die Steuerungsplatine der A700 umsetzen lassen.
Für die motivierten Engagierten kann ich auch die R-Werte beisteuern:
.pdf   TCA561_resistor_values.pdf (Größe: 126.84 KB / Downloads: 61)
mfg Pit
weitere Detailinfo aus der Service-Information SI_113-87_D-E_A67-B67MKI_Mod.pdf:
die Faselec Spec.:
PS 09/2023: es gibt Neuigkeiten im (weiter unten) von <havox> verlinkten 'tapeheads-thread'! Umfeld TCA561...
TCA insights by Varga... Tinmans Statement:
Tinman schrieb:  It's a really nice deck WHEN it behaves. But it was a stretch when new, and 70's IC's in particular aren't aging well. Many are now decaying from the INSIDE, regardless of being used or not.
und anderswo:
Tinman schrieb:(watch those Red Devils!) [aka Tantalperlen; mfg Pit]
Varga nochmal:
Varga schrieb:And to answer your last question, tape tension or contact pressure with the head if you want to properly set it is dark magic. Usually its good enough to just tension the tape so that it sounds right but if you really want to be serious, you feed the deck a 1ktone and look at it with a spectrum analyser. There is a point where too little tension will impede HF response, but too much tension (besides wearing down your heads and tape faster) will cause excessive higher order distortion in the reproduced signal. I have not yet figured out precisely why, but it happens. Also the noise from the tape is going to get worse, but thats simply because of the dragging on the guide surfaces and the heads themselves. Its all a fine balance if you really want to go proper about it. I am pretty sure that the A700 was set from the meanufacturing correctly s no need to touch the springs Smile
wie's dem KiWi-Mann erging beim 'Substituieren':
Leonivs Erkenntnisse zur Motorsteuerung:
.pdf   A-700_Leonivs_Erkundungen_Motorsteuerung_Leoniv_ E-004 MOT.pdf (Größe: 1.88 MB / Downloads: 26)
TCA561 letzter Stand (im Mai 2024 & August 2025)... Tinmans 'reloop' zu Semihs Frühwerk (obsolet im Jahre 2024, mittlerweile 17 Jahre her, dennoch immernoch bewundernswert)
important TCA561 Clone-Info Juni 2025... Idee: ev. besteht ein Zusammenhang mit dem bekannten Interferenzbrumm der Wickelmotoren (siehe auch die .wav files in Leonis .pdf) - mal so ins Unreine gedacht mfg Pit 14.07.2025, drei Wochen nach dem Tod von Guido Besimo
©DK1TCP Semih Leoniv Tinman TCA561 A700 A-700 #unobtainium #Interferenzbrumm #tapeheads weggebrochen? (08/'25) z.Zt. nur über Smartphone erreichbar, nicht über PC-Browser... 6.8.'25: geht wieder...
zur Entstehung der A-810: S.2 ff im ersten SwissSound von 1982
Ich habe noch ein Datenblatt von Faselec zum TCA561 gefunden
.pdf   TCA561_50.05.0152_DataSheet.pdf (Größe: 959.7 KB / Downloads: 50)
Ersatz für TCA561 über ESP32
Beispiel Hier!
Und hier ist der zugehörige thread bei tapeheads:
https://www.tapeheads.net/threads/a700-r...-go.99864/
Hans-Volker
