18.01.2021, 12:15
Hello,
Thank you for your advice. The problem seems to be solved!
It looks as it were the pins of the remote connector. The pins of the connector were badly soldered together.
But there is still an other problem: there are small volume fluctuations now an then. The fluctuations are on the recordings. The volume drops a few decibels (+/- 3db) every 30 minutes or so. The problem occurs on both speeds: 38 cm/s (less) and 19cm/s (more frequently and more decibels I think). I demagnitised both heads and rolls and I changed the tape but this didn't solve the problem. Do you have any suggestions?
Best regards
Evert
Best regards
Evert
