I would like to share a small technical adjustment I made to the X-7.
The X-7 often suffers from a slow, fast forward and reverse movement, especially shortly before the end of the recording tape, the movement creeps or even comes to a standstill shortly before without reaching the end of the tape.
In my opinion, the reason for this is the hard-wired, i.e. non-adjustable, counter-tension of the respective supply winding motor.
Questions in forums on this subject have usually already involved cleaning the commutators of the motors or replacing the capacitance of the power supply unit without success in terms of fast winding.
Among other things, the changeover of the energy provider from 220V AC to 230V AC is probably causing additional problems for the already difficult conditions on fast winding, the higher voltage increases the back tension, too.
I have therefore included an adjustable option in the circuit which reduces the back tension so fast winding is relatively quickly again.
To do this, I added a series-connected resistor trimmer to R127 (10k) so that the back tension can be reduced more by increasing the resistance.
R118 is used to control the left-hand winding motor (tape supply motor) via Q70 and the right-hand winding motor (take up winding motor) via R119 and Q71.
Best regards
**************************** in german ******************************************
Ich möchte einen von mir gemachte kleine technische Anpassung an der X-7 zur Verfügung stellen.
Vielfach kränkelt die X-7 an einen langsamen schnellen Vor- und Rücklauf, insbesondere kurz vor Bandende schleicht die Bewegung oder kommt kurz zuvor sogar zum Stehen ohne das Bandende zu erreichen.
Hintergrund ist meines Erachtens der festverdrahte, also nicht veränderbare Gegenzug, also des jeweiligen abwickelnden Wickelmotors.
Bei Fragen in Foren zum Thema sind in der Regel bereits die Kommutatoren der Motoren gereinigt worden oder auch die Siebkapazitäten des Netzteils erneuert worden ohne Erfolg in Bezug auf das schnelle Spulen.
Wahrscheinlich macht u.a. auch die Umstellung der EVUs von 220V AC auf 230V AC dem schon im Vorfeld schwierigen Bedingungen beim Spulen noch zusätzlich Probleme, da damit der Gegenzug spannungsbedingt nochmals anwächst.
Daher habe ich eine einstellbare Möglichkeit in die Schaltung mit eingebracht welche den Gegenzug reduziert, so dass es beim schnellen Vor- und Rücklauf wieder relativ flot zur Sache geht.
Dazu habe ich R127 (10k) um einen in Serie geschalteten Trimmer ergänzt, so dass durch eine Widerstandserhöhung der Gegenzug stärker abgesenkt werden kann.
Über R118 wird über Q70 der linke Wickelmotor (abwickelnder Motor) angesteuert und über R119 und Q71 der rechte Wickelmotor (aufwickelnder Motor).
Best regards
Noa and Mira Awad
NOA Keren Or
ESC
ESC Diva
reVox B251 Revision und Modifikationsliste!
Noa and Mira Awad
NOA Keren Or
ESC
ESC Diva
