10.07.2005, 19:31
I have a cc20 cassette deck, but it has the following problem: when playing tapes , there seems to be too much torque on the take up spool and the tape gets crinkled and creased by the pinch roller. I have replaced the pinch roller which helped a bit but not much.
opening the unit I found that the spool motor is connected to the spools by a clutch. in playback mode without a tape in, grabbing the take up spool caused the motor to stop; there was no slipping on the clutch. Is this normal? I am assuming the clutch needs to be repaired or replaced, but thought I would ask first....
hope someone can spare a moment to give an opinion, it would be much appreciated!
regards, Ben
PS. Leider kann ich solche tecknische Details in Deutsch nicht gut ausdruecken!! deswegen habe ich Englisch geschrieben. Es waere aber kein Problem wenn sie eine Beantwortung auf Deutsch schreiben koennen
regards, Ben
