(20.09.2022, 21:01)Magnettonmanni schrieb: Hello Paulo,fortunately i have some spare parts available, do you intend one of this assembly?
the picture shows a solution that is not originally intended by Telefunken for normal devices.
Just a flywheel is not enough. This must be kept at the desired speed during the standby phase by a drive wheel at the bottom of the capstan motor.
It must not be started up by the tape. Then the tape gets overstretched.
You say you still have an M10. There, the second flywheel also must be driven by the large flywheel via an intermediate wheel.
If this axis creates a tape-tension of 40-50 p, you can leave it like that for now. All other intermediate solutions outside of the original ones would only get worse.
Best regards
i want thanks you for accurate description,,, its very helpful for me..
how can i measure this tape tension of 40-50 p, what is p?
