19.05.2009, 18:59
Inside my Z124 finally the main transformer was burned after more than 1 hour of continuous recording
After that I replaced the internal transformer with an external one but inside the unit something were hot, so finally discovered that the heat came from the diode bridge. I replaced it with a smaller and more modern diode bridge and soldered to it a 5th diode, because in the original diode bridge were another diode inside.
After that, now all works OK and the voltage is good even while recording. I get 6.2V then.
![[Bild: z124jj1.jpg]](http://i216.photobucket.com/albums/cc46/thereeler/z124jj1.jpg)
![[Bild: z124jj2.jpg]](http://i216.photobucket.com/albums/cc46/thereeler/z124jj2.jpg)
