19.04.2009, 14:16
Now you should have the schma you've searched for.
The transformer may be the problem, so you should try to measure the two parts of the transformer (blue-yellow and green-red). Both windings should have the same resistance. Is it so?
Before that you should remove the voltage switch (110 V / 220 V). If the transformer ist okay, we should try to find the problem again.
Greetings Jens
Greetings Jens
