13.09.2026, 23:35
I am currently having my Gründig CF5500 serviced, almost all the know family diseases have been cured:
- dirty potentiometers and switches, some of which were replaced
- cracks in the soldering points
- the belt and roller replaced
- drive and electronics adjusted to the specs
Some modifications were made as well:
- now it is possible to see the actual recorded sound on the indicator while recording and switch between Source and Tape, like in normal decks
- the know problem of the solenoid not receiving its 12 V was also solved.
But the problem with AUT, or Automatic Recording Level adjustment doesn’t come easy. When activated, the sound recorded with audible distortion. All the controls were cleaned, the levels adjusted according to the service manual.
Will appreciate if someone could help direct me into the right way to solve that issue.
