AKAI GX-77 short presentation inside out
AKAI GX-77 and its current weaknesses!
This small open reel tape machine for reels up to 18cm is very compact and user-friendly. The solution to insert a Tape is easy to practice, as it is cool designed to be easy to use, eliminating the need for following the tape paths that require finger acrobatics.
Despite its three-motor drive, the AKAI GX-77 has some design weaknesses. As with the small Philips tape recorders, the rewind motors are connected to the reel plates via belts. The capstan drive is belt-driven too.
Due to the compact design, the delicate drives are small DC motors with mechanical commutators that are guided by brushes.
As a result, these motors have now reached the point where age and wear are becoming an issue.
The AKAI GX-77 often struggles with fast winding with small winding core diameters, resulting in premature stoppage or near stoppage before the end of the tape.
Unfortunately, the winding motors have lost their vigour and power with age. This can be remedied by oiling the bearings and making a technical adjustment to the power supply's current limitation, as well as a circuitry adjustment in the electronics (higher Backtension Resistor, and I add a Z-Diode for cut backtension at slow rotation spped) the tape tension during fast winding. This makes it possible to adequately address the problem.
However, the capstan motor also struggles over the years, too, the urge to move can come to a premature halt. This usually happens after a few minutes of flawless playback. First, the tape speed slows down rapidly until the transport comes to a complete standstill.
This is where the thermal resistor (PTC) pretect the electronic when the capstan motor's power requirements increase (up to 200mA can be okay, for the PTC) I replaced the PTC by a Polyfuse with hold current 250mA. The thermal resistor is designed to protect the capstan motor and motor electronics from damage. The increased power requirement results partly from the capstan motor itself, bearing lubrication and collector contamination, but also from the mechanics to be driven, consisting of flywheels and control wheels, which are in need of new lubricant.
The AKAI GX-77 continues to cause headaches due to the numerous switches, including those on the audio electronics, as well as the built-in reed relays.
This means that when overhauling the tape machine, in addition to dismantling and cleaning the numerous switches and belts, the reed relays also need to be replaced.
All in all, this means that an unrefurbished AKAI GX-77 requires truly exorbitant repair costs that are hardly affordable. In fact, unmaintained devices can only be given away, because they require a great deal of effort to repair!
PS: The mechanism at the counter/loading roller breaks and becomes defective. However, it can be easily repaired with a replacement part that is available for purchase or through creative DIY.
AKAI GX-77 und ihre heutigen Schwächen!
Die kleine Bandmaschine für maximal 18cm Spulen ist sehr kompakt und Anwenderfreundlich aufgebaut. Besonders gelungen ist die Lösung der Bandeinfädelung, welche einfach in seiner Handhabung konstruiert wurde, so dass kein umständlicher Bandpfad zur Fingerakrobatik zwingt.
Trotz des drei Motorenlaufwerks bringt die AKAI GX-77 konstruktiven Schwächen mit. Die Wickelmotere sind wie bei den kleinen Philips Tonbandgeräten über Riemen mit den Spulentellern gekoppelt. Der Tonwellenantrieb erfolgt über eine riemengeführte Kopplung zum Tonmotor.
Bedingt durch die Kompaktheit im Aufbau sind die zierlichen Antriebe kleine Gleichstrommotore mit mech. Kommutator der über Bürsten geführt wird.
Daher sind diese Motoren auch inzwischen an den Pukt gekommen wo Alter und Verschleiß eine Rolle spielt.
Oft tut sich die AKAI GX-77 beim schnellen Spulen mit kleinen Wickelkerndurchmessern schwer, so dass es vor Bandende zu einem vorzeitigen Stillstand kommt oder beinahe zu einem solchen.
Die Wickelmotore haben mit ihrem zunemenden Alter leider an Pep und Kraft eingebüst. Helfen kann hier Lager ölen und eine tech. Anpassung der speisenden Strombegrenzung im Netzteil sowie einer schaltungstechnischen Anpassung im Bereich der Elektronik für den Gegenzug beim schnellen Spulen. Damit ist es möglich den Mangel ausreichend zu begegnen.
Aber auch die Seite des Tonmotors tut sich mit den Jahren schwer, auch hier kann der Bewegungsdrang vorzeitig zum Stillstand kommen. Dies, in der Regel, nach wenigen Minuten einwandfreien Abspielens. Zunächst wird die Bandgeschwindigkeit rapide langsamer bis zum Schluß der Transport zum völligen Stillstand kommt.
Hier spielt die Thermosicherung bei erhöhtem Strombedarfs des Tonmotors den Spielverderber. Die Thermosicherung soll Tonmotor und Tonmotorelektronik vor Schaden schützen. Der erhöte Strombedarf resultiert zum einem vom Tonmotor selbst, Lagerschmierung und Kollektorverschmutzung aber auch die anzutreibende Meschanik bestehend aus Schwungräder und Steuerrädern sind mit der Grund, welche sich nach neuen Schmierstoff sehnen.
Bauchschmerzen an der AKAI GX-77 entstehen weiterhin an den zahlreichen Umschalter u.a. an der Audioelektronik, sowie an den verbauten Reeedrelais.
Demnach ist bei einer Überholung der Bandmaschine neben der Zerlegung und Reinigung der zahlreichen Schalter, Riemen auch der Austausch der Reedrelais erforderlich.
In der Summe bedeutet es, dass in einer nicht überarbeiteten AKAI GX-77 ein wirklicher exorbitanter Instandsetzungsaufwand schlummert, der kaum mönitär zu stämmen ist. Eigentlich lassen sich ungewartete Geräte nur verschenken, denn es muss ein umfangreicher Aufwand aufgebracht werden!
PS: 2025-12-03-> Ergänzung von technischen Hinweisen im englischen Textteil, im deutschen sind diese nicht von mir benannt/ergänzt!
Hallo Thomas,
sehr schön beschrieben. Bisher bin ich bei meiner von den typischen Problemen mit den Wickelmotoren verschont geblieben. Allerdings arbeitet im Moment der Fädelmechanismus nicht. Da muss ich wohl mal dran. Ist schließlich bald Weihnachtsurlaub.
Ich habe so eine geerbt, einmal bei TGE in Essen überholen lassen, für ein paar €.
Die macht seit Jahren die Gäste in meinem Partykeller glücklich (mit Rockmusik), und die Kunden der 18-cm-Bänder beim Analogforum Moers (mit Klassik oder Jazz). Ist Viertelspur, aber meine Bandkopien mit Schmetterlingsköpfen lassen sich da wirklich super anhören!
Unterwegs als „Tonmeister h.c.“ unter www.tapemusic.eu[url=www.tapemusic.eu][/url]
(02.12.2025, 21:15)Wicki 1968 schrieb: .....Bisher bin ich bei meiner von den typischen Problemen mit den Wickelmotoren verschont geblieben. Allerdings arbeitet im Moment der Fädelmechanismus nicht. Da muss ich wohl mal dran. Ist schließlich bald Weihnachtsurlaub.
Hi Frank,
das ist leider ebenfalls eine elementare Schwäche an der GX-77, dass die mech. der Umlenk-Zählerrolle durch Bruch defekt geht. Läßt sich aber durch käuflichen Ersatz bzw. durch kreative Selbsthilfe gut instandsetzen.
Dafür hatte Akai sogar mal einen Servicehinweis rausgebracht. Man sollte dort eine Schraube als Federhalterung verbauen. (so wie auf dem Bild)
Die Plastiknase bricht nämlich irgendwann ab.
Hab ich bei mir auch so gemacht.
Man muß nur nach "AKAI GX-77 Loading Roller" googeln, dann erhält man jede Menge Treffer zu dem Problem.
