Themen: 7
Hi!
My ASC 6002 sometimes doesn't play due to capstan motor.
Capstan motor sometimes doesn't rotate especially after long no use.
If i forced to rotate with my hand, then it rotate and play as nomal.
I know capstan motor is hall motor. so I think it doesn't have dead spot like DC motor .
what is cause and remedy for thios?
Thans in advance.
Themen: 71
Helge
Revox A77 Mk II
Sony TC-758
Braun TG 1000
Marantz Model 5220
ASC 6002 S
To make it short. Change the potentiometer R1305 on the motor board first. It should have 100 Ohms but it degrades over the years. When the resistance is to high the hall elements don´t get enough current.
Themen: 7
Hi!
thank you.
Is it potentiometer R1303?
R 1305 is fixed resistor with 12 ohm.
Jaehong
Themen: 71
Look at the picture in the thread I linked to yesterday:
https://tonbandforum.de/showthread.php?t...#pid382639
It's the lying potentiometer. The numbering seems to be inconsistent. On my machine it was R1305, although that number was used for two parts there.
Helge
Revox A77 Mk II
Sony TC-758
Braun TG 1000
Marantz Model 5220
ASC 6002 S
Themen: 7
Hi.
Thank you.
I changed 100 ohm trimmer and adjusted less than 30 mV across R1301.
It seems to be working OK.
Many thanks you all.
Jaehong
Themen: 71
Great!
Helge
Revox A77 Mk II
Sony TC-758
Braun TG 1000
Marantz Model 5220
ASC 6002 S
Themen: 0
It sounds like the motor’s lubrication may have dried up or become sticky after long periods of non-use, causing the initial resistance. Even though it's a Hall motor, old/loss of lubrication or gummed-up bearings can still cause this. Try carefully applying a suitable lubricant to the motor bearings. Also, check the power supply capacitors as aging components can cause startup issues. If the issue persists, a deeper cleaning or professional servicing may be needed. Good luck!
Themen: 239
Gestern, 15:30
(Dieser Beitrag wurde zuletzt bearbeitet: Gestern, 15:32 von janbunke.)
Didn't you read what Jaehong wrote
here?
The problem has already been solved!
