USB-C Line In Kabel, gibt es das?
Aus den Spezifikationen von USB-C:
Zitat:Audio adapter accessory mode
A device with a USB-C port may support analog headsets through an audio adapter with a 3.5 mm jack, providing three analog audio channels (left and right output and microphone). The audio adapter may optionally include a USB-C charge-through port to allow 500 mA device charging. The engineering specification states that an analog headset shall not use a USB-C plug instead of a 3.5 mm plug. In other words, headsets with a USB-C plug should always support digital audio (and optionally the accessory mode).[20]
Analog signals use the USB 2.0 differential pairs (Dp and Dn for Right and Left) and the two side-band use pairs for Mic and GND. The presence of the audio accessory is signaled through the configuration channel and VCONN.
Also geht natürlich analog raus (in Stereo) sowie Mikrofon-In. Wink
Thema erledigt, extra (externes) Gerät benutzen, um den Apfel sinnvoll zum Messen zu verwenden.
The 7 P's: Prior proper planning prevents piss-poor performance.  Cool
Nachrichten in diesem Thema
RE: USB-C Line In Kabel, gibt es das? - von proso - 28.04.2025, 12:37
