Uher 4000 C 38 questions
Hello all, I am looking info on eq. of C38 and too info on diameter of two motor pulleys put on Buhler motor.
Is there a diagram of C38, exist ?
If someone has the two motor pulleys, send me a pm, thanks.
All best.
Lpr35.
Hello Raffaello,
I've sent you lots of Information and how to find more details here in the forum but never got any feedback from you. My questions on what you are planning and how to help you  have been ignored, too. So please re-read my messages, the threads in the forum and let us know the specific Problems.
The EQ changes i made have been described in the forum as well and I don't have any official documents on that topic.
Regards
Festina lente!
Hello, I want modify my 4200 Report Stereo to 38 cm/s. I am working on this machine from some years, and I have changed all components, interal wires too . New resistors, new caps, new drive wheel, and other parts too.
Remain always the problem of 0.15% of wow flutter wieghted to 19 cm/s speed ; ; for this reason I wanted see if to 38 the flutter problem goes away for always .
Thanks.
Hallo Raffaello!
A picture from the equalizer circuit board (component side):
Greetings
Edit:
The circuit board from the other side:
The other Capacitor-data:
There is no chance to measure the pulleys, when the motor
is in the Report.
I don´t want to remove the motor. Because there is only one
position, in which the motor is working.
Please take your IC-pulleys measures and convert them to
the size 38cm/s ...
Ok, thanks.
Hi,
one picture of two that you want from the equalization board:
...more in the PN...
Greeting
