04.08.2017, 01:58
Greetings everyone!
I recently bought a Telefunken M12. This has been unused for many years. Nothing worked. I repaired the transport board, had 2 relay with the cut coil. Luckily I could repair the relay by putting new coils.
Now, I find that a coil from the Play head is cut off. Only one channel works I need a new play head.
Can I put a better play head? what dou you recommend?
The recorder has very little use. Surely they stopped using it, when the play head was broken.
Thank you all for helping me!
Regards,
Rolando
Regards,
Rolando
