09.05.2017, 19:07
Hi Ken,
are you sure about "Z127" ?
In the documentation that I have seen, the power supply is called Z124 A1.
Uher specifies the supply voltage range in the schematic as 5.3 to 7.5 V.
You can get the service manual in the download section of this forum.
This requires a separate registration.
That manual is, however, incomplete. The final pages with drawings of the PCBs and schematic are missing.
You can get two different versions of scans of those drawings and schematic at
http://tonbandwelt.magnetofon.de/uher/
with these links:
http://tonbandwelt.magnetofon.de/uher/monitor/serva.htm
http://tonbandwelt.magnetofon.de/uher/4xxxms/4xxx.htm
Did you order from http://www.uher.sds-consult.de/ ?
Could you illustrate your question regarding the "red leaf type switch" with a fotograph of that part ?
Regards Kai
with these links:
Regards Kai
